[GRASS-dev] Re: [GRASS GIS] #548: grass7: v.reclass segfaults on string column
GRASS GIS trac at osgeo.org
Tue Aug 4 02:38:03 EDT 2009
  Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:  v.reclass
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by martinl):
 * cc: martinl` (added)
  * keywords:  => v.reclass
  * priority:  major => normal
Comment:
 Replying to [ticket:548 mlennert]:
 > With today's devel7 trunk, v.reclass segfaults when trying to use a
 string column as reclass criterium. Using nc_spm_06 demo data:
 > v.reclass in=boundary_county out=test_recl column=DOT_GROUP_
 > segfaults, whereas
 > v.reclass in=boundary_county out=test_recl2 column=DOT_COUNTY
 > works as expected (DOT_COUNTY is integer).
 > In grass65svn, both commands work as expected.
 > This also obviously makes v.dissolve fail on such columns.
 Works fine with DBF driver. When reclassing data using string column you
 get with SQLite driver know error.
 DBMI-SQLite driver error:
 Cannot step:
 SQL logic error or missing database
 No segfault here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:3>
