[GRASS-dev] Re: [GRASS GIS] #710: v.db.select: allow output to a file
GRASS GIS trac at osgeo.org
Tue Aug 4 03:51:20 EDT 2009
  Reporter:  mlennert     |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.5.0
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:  v.db.select file
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by mlennert):
 Replying to [comment:2 martinl]:
 > Slightly changed patch applied in trunk, r38606. I have changed "output"
 to "file". If reasonable I will backport it to devbr6.
 Thanks a lot. Should this also be implemented in db.select ?
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/710#comment:5>
