[GRASS-dev] compiling today's grass7 trunk: ogr_srs_api.h: No
such file or directory
Moritz Lennert
mlennert at club.worldonline.be
Wed Aug 5 06:25:35 EDT 2009
I'm having the same problem again with today's svn trunk:
gcc
-I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include
-Wall -g -O2 -fPIC -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
-I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -o
OBJ.i486-pc-linux-gnu/find_vect.o -c find_vect.c
find_vect.c:22:21: error: ogr_api.h: Aucun fichier ou répertoire de ce type
find_vect.c: In function ‘find_ogr’:
find_vect.c:96: error: ‘OGRDataSourceH’ undeclared (first use in this
function)
find_vect.c:96: error: (Each undeclared identifier is reported only once
find_vect.c:96: error: for each function it appears in.)
find_vect.c:96: error: expected ‘;’ before ‘Ogr_ds’
find_vect.c:100: warning: implicit declaration of function ‘OGRRegisterAll’
find_vect.c:103: error: ‘Ogr_ds’ undeclared (first use in this function)
find_vect.c:103: warning: implicit declaration of function ‘OGROpen’
make: *** [OBJ.i486-pc-linux-gnu/find_vect.o] Erreur 1
I can solve that with the following:
Index: lib/gis/Makefile
--- lib/gis/Makefile (révision 38619)
+++ lib/gis/Makefile (copie de travail)
@@ -4,7 +4,7 @@
EXTRA_LIBS = $(DATETIMELIB) $(PTHREADLIBPATH) $(PTHREADLIB) \
$(INTLLIB) $(MATHLIB) $(ZLIBLIBPATH) $(ZLIB) $(GDALLIBS)
-EXTRA_INC = $(ZLIBINCPATH) $(PTHREADINCPATH)
+EXTRA_INC = $(GDALCFLAGS) $(ZLIBINCPATH) $(PTHREADINCPATH)
DATASRC = ellipse.table datum.table datumtransform.table FIPS.code
state27 state83 projections
but am not sure that this is the correct approach.
Can someone tell me if it is ?
Moritz
