[GRASS-dev] About the vector changes
Markus Metz markus.metz.giswork at googlemail.com
Fri Aug 7 03:04:02 EDT 2009
Hamish wrote:
> Glynn wrote:
>> Vector maps no longer work:
>> $ v.info fields
>> ERROR: Spatial index was written with LFS but this GRASS version does not
>>        support LFS. Try to rebuild topology or upgrade GRASS.
> Hi,
> I've got nothing to add about that; just while on the subject: it would
> be nice if v.info could work (even partially) for maps without topology
> built. e.g. massive LIDAR datasets.
It could be useful if more vector modules could support vectors without
topology, most importantly all v.surf.* modules. Not a new idea, was
mentioned earlier.
Markus M
