[GRASS-dev] r.terraflow broken
Andrew Danner
adanner at cs.swarthmore.edu
Fri Aug 7 16:09:42 EDT 2009
Can we just initialize the MM_manager to ignore memory limits until we have
a chance
to set and enforce a limit? The change below allowed me to at least compile
and run the help
--- lib/iostream/mm.cc (revision 38633)
+++ lib/iostream/mm.cc (working copy)
@@ -458,7 +458,7 @@
MM_register MM_manager;
int MM_register::instances = 0; // Number of instances. (init)
// TPIE's "register memory requests" flag
-MM_mode MM_register::register_new = MM_ABORT_ON_MEMORY_EXCEEDED;
+MM_mode MM_register::register_new = MM_IGNORE_MEMORY_EXCEEDED;
On Wed, Aug 5, 2009 at 6:14 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Laura Toma wrote:
> > The problem is that it attempts to set the memory manager limit to 0
> > (see below: limit=0B), and the first line in
> > MM_register::set_memory_limit(size_t new_limit)
> > is
> > assert(new_limit>0).
> > Therefore the problem.
> > So the question is, why does it try to set the memory limit to 0?
> > Unless the user specifies a value, the default value is 300MB, see
> > main.cc:
> > mem->answer="300";
> > opt->mem = atoi(mem->answer);
> > size_t mm_size = opt->mem << 20; /* opt->mem is in MB */
> > MM_manager.set_memory_limit(mm_size);
> It doesn't even get as far as main(), let alone parsing and using the
> mem= option:
> $ gdb r.terraflow
> Program received signal SIGABRT, Aborted.
> [Switching to Thread 0xb6bcf9a0 (LWP 668)]
> 0xb7fd4424 in __kernel_vsyscall ()
> > where
> #0 0xb7fd4424 in __kernel_vsyscall ()
> #1 0xb7d42311 in *__GI_raise (sig=6)
> at ../nptl/sysdeps/unix/sysv/linux/raise.c:64
> #2 0xb7d43bf8 in *__GI_abort () at abort.c:88
> #3 0xb7d3b6df in *__GI___assert_fail (
> assertion=0x6 <Address 0x6 out of bounds>,
> file=0x6 <Address 0x6 out of bounds>, line=6,
> function=0x80e3985 "void* operator new(size_t)") at assert.c:78
> #4 0x080c8985 in operator new (sz=24) at mm.cc:344
> #5 0xb6ec7c2f in global constructors keyed to _ZN4geos7ProfileC2ESs ()
> at ../util/Profiler.cpp:20
> #6 0xb6ec8165 in __do_global_ctors_aux () from /usr/lib/libgeos.so.2
> #7 0xb6e3a3c9 in _init () from /usr/lib/libgeos.so.2
> #8 0xb7fe3a77 in call_init (l=0xb6ef3108, argc=2, argv=0xbfead4c4,
> env=0xbfead4d0) at dl-init.c:70
> #9 0xb7fe3b16 in _dl_init (main_map=0xb7ff2658, argc=2, argv=0xbfead4c4,
> env=0xbfead4d0) at dl-init.c:134
> #10 0xb7fd59df in _dl_start_user () from /lib/ld-linux.so.2
> The assert is triggering in the constructor for a static variable
> within the GEOS library (linked in by GDAL).
> geos-2.2.3/source/util/Profiler.cpp has:
> static Profiler *internal_profiler = new Profiler();
> This gets called before main(), but the customised "operator new()" in
> lib/iostream doesn't work until the memory manager has been
> initialised, which doesn't occur until G_parser() has been called.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090807/151fe5be/attachment-0001.html
