[GRASS-dev] Re: [GRASS GIS] #151: make documentation be full text
searchable: use sphinx
trac at osgeo.org
Sun Aug 9 04:13:01 EDT 2009
#151: make documentation be full text searchable: use sphinx
Reporter: timmie | Owner: epatton
Type: enhancement | Status: assigned
Priority: major | Milestone: 7.0.0
Component: Website | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by neteler):
I have locally converted '''most''' pages (using html2rest.py by Gerard
Flanagan at http://bazaar.launchpad.net/~grflanagan/python-
rattlebag/trunk/annotate/head:/src/html2rest.py ), a set of the GRASS HTML
files fails with problems like
reST markup error:
/home/neteler/grass65/dist.x86_64-unknown-linux-
gnu/docs/html/rst/source/r.coin.rst:66: (SEVERE/4) Title level
inconsistent:
make: *** [html] Error 1
or
reST markup error:
gnu/docs/html/rst/source/r.cost.rst:183: (SEVERE/4) Title level
inconsistent:
Algorithm notes
This indicates to some extent HTML errors in the original as well as
Sphinx problems with the tags
<dt> ...
<dd> ...
So with some effort the HTML pages could be made Sphinx compliant (perfect
power user job).
Here the list of failing HTML files in 6.5.svn: d.graph.rst, d.his.rst,
d.linegraph.rst, d.mapgraph.rst, d.menu.rst, d.out.file.rst,
d.text.freetype.rst, g.gisenv.rst, g.message.rst, grass6.rst,
g.region.rst, i.ortho.photo.rst, m.proj.rst, ps.map.rst, r.category.rst,
r.coin.rst, r.cost.rst, r.distance.rst, r.in.gdal.rst, r.in.xyz.rst,
r.mfilter.fp.rst, r.mfilter.rst, r.out.gdal.rst, r.proj.rst, r.ros.rst,
r.spreadpath.rst, r.spread.rst, r.terraflow.rst, r.tileset.rst,
r.watershed.rst, r.what.rst, v.label.rst, v.lidar.correction.rst,
v.lidar.edgedetection.rst, v.lidar.growing.rst, v.outlier.rst,
v.reclass.rst, v.segment.rst, v.surf.bspline.rst.
I've put everything online give you an impression (yes, partially messy
but not so bad...):
http://grass.osgeo.org/grass65/manuals/sphinx/
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/151#comment:6>
