[GRASS-dev] Re: About the vector changes
Markus Metz
markus.metz.giswork at googlemail.com
Sun Aug 9 11:11:45 EDT 2009
Glynn Clements wrote:
> Markus Metz wrote:
>>> d.vect, etc use the libraries and VECT_CFLAGS, so it isn't just v.*
>>> modules which need to be checked. It might just be v.* modules which
>>> need to be fixed; I don't know.
>> OK. I will check all modules including <grass/vector.h> or any of the
>> headers in include/vect. All vector modules should be fixed by now. Of
>> the raster modules, only r.drain needed fixing, all other were ok. But I
>> will check again.
> I suggest checking for VECT_CFLAGS in the Makefiles.
I've done that already. I also checked for <grass/vector.h> in g.* and
r.* modules, it looks all fine to me. The import/export modules are a
different issue, they may need extra attention to become LFS-safe. Also
some libraries, Helena said rst needs fixing, not sure about others like
the segment library.
>>> ideally, we should use G_{fseek,ftell} everywhere. Ultimately, it
>>> would be better to enable -D_FILE_OFFSET_BITS=64 globally (to ensure
>>> that there aren't any cases where a FILE* is obtained via fopen64()
>>> then passed to code which can't handle it), which means making
>>> everything LFS-aware.
>> That's beyond my scope because aclocal.m4 and configure.in need
>> adjustment, and I won't touch these. I guess you are suitably qualified
>> for the task ;-)
> The build system changes are straigtforward; just set
> _FILE_OFFSET_BITS in config.h (this is already done, but it's
> conditional upon USE_LARGEFILES, which doesn't get set).
I thought USE_LARGEFILES is set in configure and passed to
Platform.make.in line 248
> The effort is in ensuring that code doesn't fail in inconvenient ways
> (i.e. corrupting data) when dealing with files >2GiB, i.e. converting
> everything to use off_t.
Is it possible that configure sets LFS_FLAGS as a result of the LFS
tests which are stolen from cdrtools and in aclocal.m4?
It would be easier if configure could check if all we need is
_FILE_OFFSET_BITS and not also conditionally _LARGE_FILES,
_LARGEFILE_SOURCE, -n32 for LFS to work on 32bit systems.
Markus M
