[GRASS-dev] Re: [GRASS GIS] #335: export floats and doubles with
correct precision
trac at osgeo.org
Sun Aug 9 23:56:29 EDT 2009
#335: export floats and doubles with correct precision
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords: precision
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
is there any reason not to change the following to %.15g?
raster/r.colors/
rules.c:47: sprintf(minstr, "%.25f", (double)min);
rules.c:48: sprintf(maxstr, "%.25f", (double)max);
AFAIK %.25f for a double (DCELL) is just reporting noise. It causes out-
of-range white areas on a raster map because the 0%,100% color rules are
no longer == the actual floating point value (50% chance it falls on the
outside of the range)
also, in lib/gis/color_write.c:
#define PRECISION 30
#define THRESHOLD .0000000000000000000000000000005
/* .5 * 10 ^(-30) */
static int format_min(char *str, double dval)
double dtmp;
sprintf(str, "%.*f", PRECISION, dval);
G_trim_decimal(str);
sscanf(str, "%lf", &dtmp);
if (dtmp != dval) { /* if no zeros after decimal point were
trimmed */
sprintf(str, "%.*f", PRECISION, dval - THRESHOLD);
/* because precision is probably higher than PRECISION */
return 0;
(max is similar but adds the spillover threshold; but apparently this
doesn't have the desired effect as 5e-31 is swept away in the noise
anyway. ?)
I blindly guess number originally came from an attempt to be a wee bit
bigger than 1e-32. ???? (dates back to CVS rev1.1 so no help
from the commit history)
i.e. can we always assume DCELL|double to be the same bit depth, and %.15g
the most we'll ever be able to squeeze from it?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/335#comment:6>
