[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
trac at osgeo.org
Thu Aug 13 00:57:41 EDT 2009
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.li
Platform: MacOSX | Cpu: All
Changes (by hamish):
* cc: pcav (added)
* keywords: => r.li
Comment:
William wrote (on grass-user):
I did a little crude debugging yesterday (G_message) and
found it failed for me in daemon.c, line 626 / nextArea()
else {
return next(g, m);
But all this tells me is that at this point the mask name
is missing, not where it was lost.
Paolo added:
I'm also having problems with r.li:
> r.li.shannon map=uso conf=latignano_5 output=provaln
WARNING: Unable to open header file for raster map <@(null)>
CHILD[pid = 1954]: unable to open mask ... continue without!!!
Segmentation fault
Debian ustable, 64 bit.
Could someone please post the series of steps needed to reproduce this
using either the NC or Spearfish datasets?
thanks
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:1>
