[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
trac at osgeo.org
Thu Aug 13 05:29:03 EDT 2009
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.li
Platform: All | Cpu: All
Changes (by neteler):
* platform: MacOSX => All
* cpu: x86-64 => All
Comment:
Replying to [comment:3 hamish]:
> also in grass7 that should be moved to ~/.grass/r.li/
Done in r38708 (but it is ~/.grass7/r.li/ to avoid confusion).
> so the G_fatal_error() in daemon.c does not kill the process?
> ah, if I give it a garbage conf file name:
> `conf=landclass96_conf.blah` it goes nuts:
> [--- It ''should'' quit everything at this point ---]
That's the point - it should not start/continue to run the workers when
the config file isn't found. I tried but I have no clue how to achieve
that.
Markus
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:5>
