[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
trac at osgeo.org
Fri Aug 14 05:52:10 EDT 2009
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.li
Platform: All | Cpu: All
Comment (by neteler):
Replying to [comment:7 pcav]:
> Right, sorry for not checking this. However, setting the right path does
not help:
As mentioned above, the path should NOT be set. conf= has to be a
filename, not a full pathname.
Please always post the command line to better illustrate the problem (also
in GUI mode available)
@devs: can we simply strip off the directory stuff?
Markus
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:8>
