[GRASS-dev] compiling today's grass7 trunk: ogr_srs_api.h: No
	such file or directory
    Martin Landa
    landa.martin at gmail.com
    Fri Aug 14 06:23:15 EDT 2009
2009/8/6 Glynn Clements <glynn at gclements.plus.com>:
> The correct approach is to revert the portion of r38552 which applies
> to lib/gis/find_vect.c, lib/gis/find_file.c, and lib/gis/Makefile.
> lib/gis has no business calling OGR functions, or even linking against
> OGR. If it's impossible to "find" a vector without them, then
> find_vect.c should be removed altogether, and the functions moved into
> the vector library.
right, I reverted changes in r38719.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
