[GRASS-dev] New: v.db.droprow
Markus Neteler neteler at osgeo.org
Fri Aug 14 06:30:56 EDT 2009
On Fri, Aug 14, 2009 at 12:16 PM, Martin Landa<landa.martin at gmail.com> wrote:
> Hi,
> 2009/8/14 Martin Landa <landa.martin at gmail.com>:
>>>> * are these extra checks needed (it's done by v.extract) [1,2]
>>> Yes, I think so: if you create a map with v.random it won't have
>>> a connected table, so better don't badly crash. Likewise with
>>> a non-existing map. I used existing msg strings (for translation).
> BTW, why are you requesting the input vector map from the current mapset?
Fixed.
Markus
