[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
GRASS GIS trac at osgeo.org
Fri Aug 14 09:20:15 EDT 2009
  Reporter:  kyngchaos  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  normal     |   Milestone:  6.4.0
 Component:  Raster     |     Version:  6.4.0 RCs
Resolution:             |    Keywords:  r.li
  Platform:  All        |         Cpu:  All
Comment (by hamish):
 Just to clarify some points,
  - the original command Paolo gave (copied in comment:1) is not to the
 full path and the
 WARNING: Unable to open header file for raster map <@(null)>
 errors appear without the failure to stat config file. Apparently failure
 to kill spawned workers on a fatal error is a coincidental bug.
  - it is not just debian/sid 64 bit, William sees it too on Mac OSX 64bit.
  - I don't see it on amd64 debain/lenny with a self-compiled 6.5svn. I
 haven't tried the debian packages there.
  - is there any MASK set or is that message just coming from no where?
 H
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:10>
