[GRASS-dev] New: v.db.droprow
    Markus Neteler
    neteler at osgeo.org
    Fri Aug 14 12:52:49 EDT 2009
On Fri, Aug 14, 2009 at 3:30 PM, Moritz
Lennert<mlennert at club.worldonline.be> wrote:
> On 14/08/09 10:43, Markus Neteler wrote:
>> On Fri, Aug 14, 2009 at 10:15 AM, Martin Landa<landa.martin at gmail.com>
>> wrote:
>>> 2009/8/11 Markus Neteler <neteler at osgeo.org>:
>>>> It removes vector objects (point, line, area, face etc.) from a vector
>>>> map through attribute selection in the table.
>>> Also not sure if we need this script.
>> How would you do vector removal based on attributes?
> v.extract -r ... where=
Ok, while I disagree that this is obvious (especially to newcomers),
I'll remove the module now in 6.5.
Markus
