[GRASS-dev] Re: [GRASS-windows] No such file or directory
Hamish hamish_b at yahoo.com
Fri Aug 14 19:54:40 EDT 2009
> [r.in.poly fails to read text input file on Windows/CMD line]
I have checked at the r.in.poly source code, the problem does
not seem to be there. The path is passed to fopen() verbatim.
what version/revision of 6.4.0svn is this? is it the latest?
ISTR that Martin&Glynn had fixed this -- wxGUI now uses a
python parser which understands shell quoting on the Cmd> line.
But that might only be present in the very latest build.
Hamish
