[GRASS-dev] [GRASS GIS] #722: r.li.daemon: respect for WORKERS
enviro var
trac at osgeo.org
Mon Aug 17 02:20:53 EDT 2009
#722: r.li.daemon: respect for WORKERS enviro var
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.li, smp | Platform: All
Cpu: All |
it would be nice if r.li.daemon respected the WORKERS environment variable
for setting the number of threads to launch.
AFAICS most of the code can be borrowed from trunk/lib/gis/worker.c.
(some doxygen comments would help)
I wonder if both the pthreads and r.li.daemon fork() code should use the
same "GRASS_WORKERS" enviro var instead of the more generic "WORKERS"
name? or is that name some pthreads standard?
or for that matter, if r.li.daemon should be adapted to use the grass7
pthreads support instead of doing its own thing?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/722>
