[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
trac at osgeo.org
Tue Aug 18 06:23:10 EDT 2009
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.li, smp
Platform: All | Cpu: All
Comment (by hamish):
I added some code to strip away the "$HOME/r.li/history/" part of the
config file name, if present.
I notice then if you give the full path to the config file on the command
line it doesn't crash with the glibc error. I suppose giving the long path
name slightly increases the memory allotment allowing the program to just
trash its own memory space and not that of its neighbors? shrug
H
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:20>
