[GRASS-dev] [GRASS GIS] #724: wxGUI: Attribute Table editor lets you modify tables from other mapsets
GRASS GIS trac at osgeo.org
Wed Aug 19 07:14:14 EDT 2009
 Reporter:  hamish      |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  6.4.0
Component:  wxGUI       |     Version:  svn-trunk
 Keywords:  db, mapset  |    Platform:  All
      Cpu:  All         |
 if you add a vector layer from another mapset (e.g. fields at PERMANENT) in
 the wx Layer Manager, then open the Attribute Table Manager GUI (last icon
 on right) you can right click on a row and select "Edit selected record".
 It lets you do that, and it successfully submits the change.
 If the mapset does not match the vector map's mapset it should only open
 the table in read-only mode and grey out most of the context menu tasks.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/724>
