[GRASS-dev] [GRASS GIS] #727: Rast_get_d_color() segfault in trunk
GRASS GIS trac at osgeo.org
Thu Aug 20 04:05:29 EDT 2009
 Reporter:  hamish                        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                        |      Status:  new
 Priority:  normal                        |   Milestone:  7.0.0
Component:  Raster                        |     Version:  svn-trunk
 Keywords:  r.what, Rast_is_null_value()  |    Platform:  Linux
      Cpu:  x86-64                        |
 I'm getting a segfault in grass7's r.what if I give it an out-of-region
 coordinate.
 e.g.
 #spearfish
 r.what -n -r input=elevation.dem east_north=1,2
 happens for both CELL, FCELL, and DCELL maps.
 gdb:
 (gdb) run -n -r input=elevation.dem east_north=1,2
 easting|northing|site_name|elevation.dem|elevation.dem_color
 ** note ** 1 2 is outside your current window
 [New Thread 0x7fedabfd06e0 (LWP 19658)]
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 0x7fedabfd06e0 (LWP 19658)]
 0x00007fedab7836c6 in Rast_is_c_null_value (cellVal=0x184ef68) at
 null_val.c:211
 211         return *cellVal == (CELL) 0x80000000;
 (gdb) l
 206        \return FALSE otherwise
 207      */
 208     int Rast_is_c_null_value(const CELL * cellVal)
 209     {
 210         /* Check if the CELL value matches the null pattern */
 212     }
 213
 214     /*!
 215        \brief To check if a FCELL raster value is set to NULL
 (gdb) bt
 #0  0x00007f937bf6b6c6 in Rast_is_c_null_value (cellVal=0x127df68) at
 null_val.c:211
 #1  0x00007f937bf6b67c in Rast_is_null_value (rast=0x127df68, data_type=0)
 at null_val.c:183
 #2  0x00007f937bf722ac in Rast_get_d_value (rast=0x127df68, data_type=0)
 at raster.c:271
 #3  0x00007f937bf5f984 in Rast__lookup_colors (raster=0x127df68,
 red=0x7fff847c559f "", grn=0x7fff847c559e "",
     blu=0x7fff847c559d "\177", set=0x7fff847c559c "", n=0,
 colors=0x7fff847c6a10, mod=0, rules_only=0, data_type=0) at
 color_look.c:261
 #4  0x00007f937bf5f55d in Rast_lookup_colors (raster=0x127df68,
 red=0x7fff847c559f "", grn=0x7fff847c559e "", blu=0x7fff847c559d "\177",
     set=0x7fff847c559c "", n=1, colors=0x7fff847c6a10, map_type=0) at
 color_look.c:90
 #5  0x00007f937bf5e546 in Rast_get_color (rast=0x127df68,
 red=0x7fff847c573c, grn=0x7fff847c5738, blu=0x7fff847c5734,
     colors=0x7fff847c6a10, map_type=0) at color_get.c:44
 #6  0x00007f937bf5e5b4 in Rast_get_c_color (rast=0x127df68,
     colors=0x7fff847c6a10) at color_get.c:71
 #7  0x0000000000402783 in main (argc=5, argv=0x7fff847d8c98) at main.c:384
 DCELL is the same but different:
 0x00007f630db80709 in Rast_is_d_null_value (dcellVal=0x22deb60) at
 null_val.c:258
 258         return *dcellVal != *dcellVal;
 (gdb) l
 253        \return TRUE if DCELL raster value is NULL
 254        \return FALSE otherwise
 255      */
 256     int Rast_is_d_null_value(const DCELL * dcellVal)
 257     {
 259     }
 260
 261     /*!
 262        \brief To insert null values into a map.
 (gdb) bt
 #0  0x00007f630db80709 in Rast_is_d_null_value (dcellVal=0x22deb60) at
 null_val.c:258
 #1  0x00007f630db80698 in Rast_is_null_value (rast=0x22deb60, data_type=2)
 at null_val.c:189
 #2  0x00007f630db872ac in Rast_get_d_value (rast=0x22deb60, data_type=2)
 at raster.c:271
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/727>
