[GRASS-dev] Re: [GRASS GIS] #726: MASK GRASS_INFO_WARNING
trac at osgeo.org
Thu Aug 20 08:39:44 EDT 2009
Reporter: pvanbosgeo | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: MASK, r.mask, startup
Platform: Unspecified | Cpu: x86-64
Comment (by pvanbosgeo):
Update: I tried the same in different mapsets, and the only mapsets that
seem to show the above-described behavior are the ones I have copied from
a backup into the current location (the original location from which the
mapsets were copied matches the current one, it is in fact an earlier
backup of the current location). I guess therefore that something has gone
wrong when copying the mapsets and this is not a general bug. It would be
good though to know if and how one can copy mapsets from a backup into the
current location.
Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/726#comment:1>
