[GRASS-dev] Re: [GRASS GIS] #736: r.proj fails in wingrass
GRASS GIS trac at osgeo.org
Wed Aug 26 04:33:56 EDT 2009
  Reporter:  cnielsen         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  6.4.0
 Component:  Raster           |     Version:  unspecified
Resolution:                   |    Keywords:  r.proj, wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hamish):
 As is the case once again with these wingrass bugs, valgrind finds some
 memory errors which are apparently benign on UNIX.
 setup:
 #get&set region
 spearfish> g.region -dbg
 #create and enter a LL/WGS84 location
 ll_wgs84> g.region n=44.50173527 s=44.37032007 \
             w=-103.87110972 e=-103.62942673 res=0:00:01 -ap
 ll_wgs84> CMD="r.proj in=elevation.dem loc=spearfish60 mapset=PERMANENT"
 ll_wgs84> valgrind --tool=memcheck --leak-check=yes --show-reachable=yes
 $CMD
 result:
 (GRASS 6.5svn on Debian/Etch 32bit i686 linux)
 ==5114== Memcheck, a memory error detector.
 ==5114== Copyright (C) 2002-2006, and GNU GPL'd, by Julian Seward et al.
 ==5114== Using LibVEX rev 1658, a library for dynamic binary translation.
 ==5114== Copyright (C) 2004-2006, and GNU GPL'd, by OpenWorks LLP.
 ==5114== Using valgrind-3.2.1-Debian, a dynamic binary instrumentation
 framework.
 ==5114== Copyright (C) 2000-2006, and GNU GPL'd, by Julian Seward et al.
 ==5114== For more details, rerun with: -v
 ==5114==
 Input Projection Parameters:  +proj=utm +zone=13 +a=6378206.4
 +rf=294.9786982 +no_defs +nadgrids=$GISBASE/etc/nad/conus
 Input Unit Factor: 1
 Output Projection Parameters:  +proj=longlat +a=6378137 +rf=298.257223563
 +no_defs +towgs84=0.000,0.000,0.000
 Output Unit Factor: 1
 Input:
 Cols: 633 (633)
 Rows: 466 (466)
 North: 4928000.000000 (4928000.000000)
 South: 4914020.000000 (4914020.000000)
 West: 590010.000000 (590010.000000)
 East: 609000.000000 (609000.000000)
 EW-res: 30.000000
 NS-res: 30.000000
 Output:
 Cols: 868 (871)
 Rows: 462 (474)
 North: 44.501667 (44.501944)
 South: 44.373333 (44.370278)
 West: -103.870556 (-103.871111)
 East: -103.629444 (-103.629167)
 EW-res: 0.000278
 NS-res: 0.000278
 Allocating memory and reading input map...
 ==5114== Syscall param write(buf) points to uninitialised byte(s)
 ==5114==    at 0x4000792: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x804BF58: main (main.c:391)
 ==5114==  Address 0x6366A0C is 2,532 bytes inside a block of size 163,840
 alloc'd
 ==5114==    at 0x401D38B: malloc (vg_replace_malloc.c:149)
 ==5114==    by 0x4037B8D: G__malloc (alloc.c:41)
 ==5114==    by 0x804C7D7: readcell (readcell.c:68)
  100%
 Projecting...
  100%
 ==5114==
 ==5114== Invalid read of size 4
 ==5114==    at 0x4010DE9: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x4004B78: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x4006792: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x479246F: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x400B44E: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x4791EDE: _dl_open (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x47946FC: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x479475D: __libc_dlopen_mode (in
 ==5114==    by 0x476E7CF: __nss_lookup_function (in
 ==5114==    by 0x476E8BF: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x47704E5: __nss_passwd_lookup (in
 ==5114==  Address 0x6361B3C is 36 bytes inside a block of size 38 alloc'd
 ==5114==    by 0x4006B83: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x471EB6E: getpwuid_r (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==
 ==5114== Conditional jump or move depends on uninitialised value(s)
 ==5114==    at 0x4008ED5: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x47928C4: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x471E499: getpwuid (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==
 ==5114==    at 0x4008B2E: (within /lib/ld-2.3.6.so)
 ==5114==
 ==5114==    at 0x4010DD3: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x6468169: (within
 /lib/tls/i686/cmov/libnss_compat-2.3.6.so)
 ==5114==    by 0x646928C: _nss_compat_getpwuid_r (in
 ==5114==  Address 0x6392C18 is 32 bytes inside a block of size 35 alloc'd
 ==5114==    by 0x471EA94: getpwuid_r (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==
 ==5114==    by 0x400A1F6: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x400A3CA: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x47924D4: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==  Address 0x6361FCC is 36 bytes inside a block of size 37 alloc'd
 r.proj complete.
 ==5114==
 ==5114== ERROR SUMMARY: 521 errors from 6 contexts (suppressed: 107 from
 1)
 ==5114== malloc/free: in use at exit: 897,236 bytes in 217 blocks.
 ==5114== malloc/free: 1,756 allocs, 1,539 frees, 1,195,737 bytes
 allocated.
 ==5114== For counts of detected errors, rerun with: -v
 ==5114== searching for pointers to 217 not-freed blocks.
 ==5114== checked 2,934,108 bytes.
 ==5114==
 ==5114==
 ==5114== 1 bytes in 1 blocks are still reachable in loss record 1 of 19
 ==5114==    at 0x401DB31: operator new(unsigned) (vg_replace_malloc.c:163)
 ==5114==    by 0x565226F: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==    by 0x56A1F04: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==    by 0x5617938: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==    by 0x400B7F4: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x400B920: (within /lib/ld-2.3.6.so)
 ==5114==    by 0x40007EE: (within /lib/ld-2.3.6.so)
 ==5114==
 ==5114==
 ==5114== 1 bytes in 1 blocks are still reachable in loss record 2 of 19
 ==5114==    by 0x56721DF: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 8 bytes in 1 blocks are still reachable in loss record 3 of 19
 ==5114==    by 0x5686C5D: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 16 bytes in 1 blocks are still reachable in loss record 4 of 19
 ==5114==    by 0x5629523: geos::GeometryFactory::GeometryFactory() (in
 ==5114==    by 0x562425A: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 16 bytes in 1 blocks are still reachable in loss record 5 of 19
 ==5114==    by 0x5624250: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 24 bytes in 1 blocks are still reachable in loss record 6 of 19
 ==5114==    by 0x56A0DEF: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 28 bytes in 1 blocks are still reachable in loss record 7 of 19
 ==5114==    by 0x566001F: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 40 bytes in 5 blocks are indirectly lost in loss record 8 of 19
 ==5114==    by 0x476E5CD: __nss_lookup_function (in
 ==5114==    by 0x6468187: ???
 ==5114==    by 0x646928C: ???
 ==5114==    by 0x4072CDC: G_whoami (whoami.c:70)
 ==5114==    by 0x4050B98: G_short_history (history.c:207)
 ==5114==    by 0x403D48C: close_new (closecell.c:311)
 ==5114==    by 0x403CBD7: G_close_cell (closecell.c:81)
 ==5114==    by 0x804C2BF: main (main.c:448)
 ==5114==
 ==5114==
 ==5114== 80 bytes in 5 blocks are indirectly lost in loss record 9 of 19
 ==5114==    by 0x475B84B: tsearch (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x476E58E: __nss_lookup_function (in
 ==5114==    by 0x6468169: ???
 ==5114==
 ==5114==
 ==5114== 140 bytes in 2 blocks are still reachable in loss record 10 of 19
 ==5114==    by 0x46FD17F: strdup (in /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x40E322C: pj_gridinfo_init (in /usr/lib/libproj.so.0.5.4)
 ==5114==    by 0x40E431A: (within /usr/lib/libproj.so.0.5.4)
 ==5114==    by 0x40E44D4: pj_gridlist_from_nadgrids (in
 ==5114==    by 0x40E07B4: pj_apply_gridshift (in
 ==5114==    by 0x40E1B35: pj_datum_transform (in
 ==5114==    by 0x40E1E1C: pj_transform (in /usr/lib/libproj.so.0.5.4)
 ==5114==    by 0x4024146: pj_do_proj (do_proj.c:84)
 ==5114==    by 0x804A055: bordwalk (bordwalk.c:56)
 ==5114==    by 0x804BB8C: main (main.c:309)
 ==5114==
 ==5114==
 ==5114== 156 (36 direct, 120 indirect) bytes in 1 blocks are definitely
 lost in loss record 11 of 19
 ==5114==    by 0x476EA09: (within /lib/tls/i686/cmov/libc-2.3.6.so)
 ==5114==    by 0x476F0F6: __nss_database_lookup (in
 ==5114==    by 0x6468149: ???
 ==5114==
 ==5114==
 ==5114== 256 bytes in 1 blocks are still reachable in loss record 12 of 19
 ==5114==    by 0x56721F3: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 256 bytes in 1 blocks are still reachable in loss record 13 of 19
 ==5114==    by 0x5686C3F: (within /usr/lib/libgeos.so.2.2.3)
 ==5114==
 ==5114==
 ==5114== 853 bytes in 80 blocks are definitely lost in loss record 14 of
 19
 ==5114==    by 0x405418E: G__location_path (location.c:80)
 ==5114==    by 0x405409E: G_location_path (location.c:41)
 ==5114==    by 0x404F7E4: G__gisinit (gisinit.c:58)
 ==5114==    by 0x804B443: main (main.c:134)
 ==5114==
 ==5114==
 ==5114== 6,696 bytes in 5 blocks are still reachable in loss record 15 of
 19
 ==5114==    at 0x401C6CA: calloc (vg_replace_malloc.c:279)
 ==5114==    by 0x4037C00: G__calloc (alloc.c:74)
 ==5114==    by 0x405A4EC: G_parser (parser.c:762)
 ==5114==    by 0x804B638: main (main.c:202)
 ==5114==
 ==5114==
 ==5114== 11,776 bytes in 1 blocks are still reachable in loss record 16 of
 19
 ==5114==    by 0x4037C6C: G__realloc (alloc.c:109)
 ==5114==    by 0x4057680: new_fileinfo (opencell.c:42)
 ==5114==    by 0x4057B2A: G__open_cell_old (opencell.c:274)
 ==5114==    by 0x4057740: G_open_cell_old (opencell.c:104)
 ==5114==    by 0x804BF26: main (main.c:389)
 ==5114==
 ==5114==
 ==5114== 20,191 bytes in 7 blocks are still reachable in loss record 17 of
 19
 ==5114==    at 0x401D487: realloc (vg_replace_malloc.c:306)
 ==5114==    by 0x4037C83: G__realloc (alloc.c:111)
 ==5114==    by 0x4046128: set_env (env.c:156)
 ==5114==    by 0x404683A: G__setenv (env.c:391)
 ==5114==    by 0x405953D: G_check_overwrite (overwrite.c:65)
 ==5114==    by 0x804B621: main (main.c:200)
 ==5114==
 ==5114==
 ==5114== 265,380 bytes in 19 blocks are still reachable in loss record 18
 of 19
 ==5114==    by 0x40DE25D: pj_malloc (in /usr/lib/libproj.so.0.5.4)
 ==5114==    by 0x40DEECF: pj_mkparam (in /usr/lib/libproj.so.0.5.4)
 ==5114==    by 0x40DD441: pj_init (in /usr/lib/libproj.so.0.5.4)
 ==5114==    by 0x402373F: pj_get_kv (get_proj.c:228)
 ==5114==    by 0x804B82D: main (main.c:234)
 ==5114==
 ==5114==
 ==5114== 591,438 bytes in 83 blocks are still reachable in loss record 19
 of 19
 ==5114==    by 0x406E110: G_store (store.c:36)
 ==5114==    by 0x4062D0C: G_set_program_name (progrm_nme.c:52)
 ==5114==    by 0x404F79C: G__gisinit (gisinit.c:51)
 ==5114==
 ==5114== LEAK SUMMARY:
 ==5114==    definitely lost: 889 bytes in 81 blocks.
 ==5114==    indirectly lost: 120 bytes in 10 blocks.
 ==5114==      possibly lost: 0 bytes in 0 blocks.
 ==5114==    still reachable: 896,227 bytes in 126 blocks.
 ==5114==         suppressed: 0 bytes in 0 blocks.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/736#comment:2>
