[GRASS-dev] GRASS 6.5 GEOS build fails
Wed Aug 26 08:45:04 EDT 2009
Martin Landa wrote:
> > but in conftest.c it is:
> > char GEOSGeom_createLinearRing();
> > No idea how to fix the test in configure.in.
> hopefully fixed in r38867.
No. Broken in r38867; fixed (i.e. reverted) in r38872.
GRASS needs GEOS 3.x; the check is supposed to fail on older versions.
