[GRASS-dev] gmath/gpde Patch for grass6.5 and grass7
Soeren Gebbert soerengebbert at googlemail.com
Thu Aug 27 15:05:46 EDT 2009
Hello Glynn,
i am sorry for the delay, the last days were very stressing for me ...
2009/8/21 Glynn Clements <glynn at gclements.plus.com>
> Soeren Gebbert wrote:
> > 3.) I can place an ATTENTION.txt file in the ccmath library folder, which
> > explains the licensing issue.
> You can't assume that someone modifying the file will have viewed the
> contents of the folder. When I open a source file, it's often from
> grep or compilation output (C-x ` or selecting a specific line of
> output), or via M-. (find-tag, i.e. locate the point in the source
> where a given symbol is defined).
> If you want to ensure that the information is seen by anyone modifying
> the file, the information needs to go into the file itself.
> What would be better still would be if subversion could restrict the
> ability to modify those files, or at least send a reminder email if
> the files are modified.
Can we modify the svn access to lib/external?
As Hamish suggested i would like to place the ccmath library into this
directory,
because other LGPL libraries are located there.
Best regards
Soeren
> An alternative would be to put the library in e.g. lib/nonGPL/ccmath
> so that the pathname serves as a reminder.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090827/4e12497f/attachment.html
