[GRASS-dev] color tables
Hamish hamish_b at yahoo.com
Thu Aug 27 19:13:48 EDT 2009
Helena wrote:
> http://skagit.meas.ncsu.edu/~helena/grasswork/grasscontrib/r.colors.html
> this just uses your rescaled png images.
Markus:
> An option might be to make a local Makefile hack to substitute
> part of the generated HTML file with a replacement including
> these images.
I don't think that's needed; just put the images in the main
body of description.html, as the color options get repeated there.
the script on the discussion side of the wiki page could be
modified to use Helena's idea of d.colortable + rotate 90 for
the mini images; no point including the d.legend frame around them. If you want a 1px frame use border="1" in the <img src.
..png please.
Hamish
