[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
trac at osgeo.org
Fri Aug 28 00:41:31 EDT 2009
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass, msys
Platform: MSWindows XP | Cpu: x86-32
Comment (by cnielsen):
Replying to [comment:14 hamish]:
> maybe "Exec" + some `FOR /F ... SET UNIXPATH=~dps0` style DOS magic?
> http://nsis.sourceforge.net/Docs/Chapter4.html#4.9.1.2
No luck so far, I managed to have the NSI script write a little batch
file, which in turn writes the 8.3 shortname to a system variable with
SETX. This value is then written to the fstab value, however it always
writes the previous value of the variable instead... annoying. Also it is
not really preferable to have a system environment variable permanently
written for this purpose...
> GRASS-Installer.nsi has code for that already?
True but msys still has problems with "/c/Program\
Files/GRASS/bin/grass64" as it strips out the \.
On another similar note, I had an error with v.digit failing to write to
the dbf because the GIS Database path had a space in it (which is the
default in the installer).
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:15>
