[GRASS-dev] Re: [GRASS GIS] #736: r.proj fails in wingrass
GRASS GIS trac at osgeo.org
Fri Aug 28 04:04:45 EDT 2009
  Reporter:  cnielsen         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  6.4.0
 Component:  Raster           |     Version:  unspecified
Resolution:                   |    Keywords:  r.proj, wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hamish):
 jef:
 > Ouch. It's not pj_free(), it's pj_dalloc()
 so, does the patch test out ok & shall we commit it?
 Index: lib/proj/get_proj.c
 --- lib/proj/get_proj.c (revision 38897)
 +++ lib/proj/get_proj.c (working copy)
 @@ -402,7 +402,7 @@
         if (str != NULL) {
             fprintf(stderr, "%s: %s\n", _("Input Projection Parameters"),
                     str);
 -           pj_free(str);
 +           pj_dalloc(str);
             fprintf(stderr, "%s: %.16g\n", _("Input Unit Factor"),
                     iproj->meters);
 @@ -415,7 +415,7 @@
         if (str != NULL) {
             fprintf(stderr, "%s: %s\n", _("Output Projection Parameters"),
                     str);
 -           pj_free(str);
 +           pj_dalloc(str);
             fprintf(stderr, "%s: %.16g\n", _("Output Unit Factor"),
                     oproj->meters);
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:9>
