[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
GRASS GIS trac at osgeo.org
Fri Aug 28 14:22:39 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass, msys
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by cnielsen):
 Replying to [comment:17 jef]:
 > In case someone is not aware:
 > And NSIS has [http://nsis.sourceforge.net/Docs/Chapter4.html#4.9.3.9
 GetFullPathName /SHORT]
 I wasn't aware, thanks jef. Patch for GRASS-Installer.nsi attached.
 Replying to [comment:16 marisn]:
 >I commited to 6.5 a hack that was sitting in my commit queue for some
 time. Please test r38898
 I tried this out and got "cannot open driver dbf". Below are the relevant
 errors I think.
 D2/3: c_table_definition()
 D3/3: c_create_bgcmd()
 cat integer
 D2/3: c_create_table() field = 1 key = cat cols = cat integer
 D1/3: Vect_default_field_info(): map = test3 field = 1
 D2/3: drv = dbf db = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
 D2/3: driver = dbf, database = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
 D2/3: opendir c:/Programs/GIS/OSGeo4W/apps/grass/grass-6.5.svn\driver\db\
 Invalid argument: can't _spawnl
 WARNING: Cannot open driver dbf
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:18>
