[GRASS-dev] Re: [GRASS GIS] #736: r.proj fails in wingrass
trac at osgeo.org
Sat Aug 29 14:47:24 EDT 2009
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: fixed | Keywords: r.proj, wingrass
Platform: MSWindows Vista | Cpu: x86-32
Comment (by jef):
Replying to [comment:12 hamish]:
> ps- I still would like to learn a bit more about how to deal with there
errors which Valgrind finds; leaving them there but ignoring them seems
like an unscratched itch. Currently I can make the reports but it's
frustrating having done that not knowing what to do next.
Without reviewing the valgrind log in detail, I'd just expect memory
leaks. Those just waste memory and are otherwise harmless, unless you run
out of memory because of them.
It didn't point to the crash. Actually it can't as there isn't any
problem valgrind could detect, because on Unix there isn't any. On Unix
the runtime library (aka libc) provides {{{malloc()}}} and {{{free()}}}
and deals with memory management for the whole process - including shared
libraries.
On Windows OTOH each DLL can have it's own runtime library and each call
to {{{malloc()}}} must be matched with a call to {{{free()}}} from the
same library.
Therefore each DLL provides a function to free allocated memory they
return, that simply calls {{{free()}}}, but from the runtime library they
use - eg. {{{pj_dalloc()}}} for PROJ, {{{CPLFree()}}} for GDAL/OGR and
{{{G_free()}}} for GRASS).
Still you won't run into problems if you compile everything using the same
runtime library, eg. one version of MinGW.
On Unix one could also call any of those or {{{free()}}} directly, without
causing problems. But one still shouldn't as the functions might do more
than just {{{free()}}} in the future. That's also why I'd consider those
issues bugs even on Unix.
Ticket URL: <https://trac.osgeo.org/grass/ticket/736#comment:13>
