[GRASS-dev] Re: options for scripts
Tue Dec 1 04:20:53 EST 2009
Michael Barton wrote:
> Potentially, are all the options listed in parser_standard_options.c
> available to be used and parsed in scripts as well as in C modules?
> I just tried 3. Two worked and one didn't. So I'm wondering which is
> the fluke--the options for database table name and database columns
> working or the one for database driver not working (actually it partly
> worked in that the wxPython menuform.py generated the correct control,
> but it lacked the list of drivers to populate it)?
> If all those in parser_standard_options.c CAN be used in scripts, then
> it is useful to update the scripting guidelines to indicate this.
I'm not sure what you're asking.
The G_OPT_* constants are only meaningful to
G_define_standard_option(), which can only be used from C.
