comparing r.cost and r.terracost [was: [GRASS-dev] Re: grass-dev Digest, Vol 43, Issue 8]
Markus Metz markus.metz.giswork at googlemail.com
Wed Dec 2 13:44:09 EST 2009
Hi Laura,
Laura Toma wrote:
> Hi Markus,
> Your conclusions are based on the hypothesis that you can model the
> performance of r.cost in the presence of low memory by tweaking the
> memory limit in the code
I think I improved disk IO, AFAICT memory limits in r.cost are handled
as before through the percent_memory option. BTW, I added an -i option
to r.cost, reporting estimated memory and disk space usage for the given
percent_memory option, inspired by r.terracost.
> and using a machine with a large physical memory. I don't think that
> this hypothesis is true, and here is the evidence so far:
> r.cost on a machine with 8GB physical memory: 1h
> r.cost on a machine with 2.5GB physical memory: 4h
r.terracost memory=2000 on a machine with 8GB physical memory: 24h
r.terracost numtiles=1 would need here 2380MB + xMB for Dijkstra Search,
but there are only 2000MB free.
r.cost on a machine with 2.5GB physical memory: >24h
> If you reboot the machine with 1GB RAM, you will see the running time
> go up (by a lot).
Please test if the running time of r.cost reaches the running time of
t.terracost.
> I have run similar tests in the past, and r.cost did not finish in 40
> hours. It may be better now
It may be so. You're welcome to test yourself. Unfortunately, I can't
afford (time contraints...) to do further testing myself, but will
continue as soon as I have some spare time. r.cost seems particularly
challenging
with regard to external memory, and I like challenges ;-)
Markus M
> , and you are the best person to re-try these tests as you know how to
> tweak it.
> I'll get back about what terracost is doing and why it has such large
> files after we see these new numbers.
> -Laura
> On Nov 17, 2009, at 3:51 PM, Markus Metz wrote:
>> Hi Laura,
>> Laura Toma wrote:
>>> Hi Markus,
>>> Processing a grid of 312 M cells takes about 8 x 312M = 2GB of RAM,
>> That is only true for r.terracost with numtiles=1, because r.terracost
>> stores costs as float. Is it possible that there is a bug in r.terracost
>> when using numtiles > 1, because creating 64GB of temporary files seems
>> a bit inordinate for 2GB of data? And if r.terracost would use double
>> for costs, it would be about 130GB of temporary files? OK, disk space is
>> nearly for free nowadays.
>> r.cost stores costs as double, so the size of temporary files is about
>> 4GB. Additionally, 2GB where used for processing, i.e. at least 6GB of
>> system RAM are required to also keep cached files in RAM.
>>> so on a machine with 8GB of RAM it will not use virtual memory at all,
>>> irrespective of how you tweak it.
>> Right, but it still uses the disk IO algorithm and reads from/writes to
>> disk.
>>> With 8GB of RAM, the correct comparison is between r.cost and
>> I don't think so because r.cost still uses its disk IO algorithm while
>> r.terracost doesn't. That's like comparing r.watershed in ram mode with
>> r.terraflow. A module not using a disk IO algorithm should always be
>> faster than a corresponding module using a disk IO algorithm, as long as
>> intermediate data fit into RAM.
>>> In other words, if you tweak r.cost, you also need to tweak
>>> r.terracost, which means you run with numtiles=1 for as long as data
>>> fits in real memory.
>> I tweaked the disk IO algorithm to be faster, not to use less disk
>> space. I can also do serious tweaking and write a true all-in-memory
>> version of r.cost and compare that to r.terracost numtiles=1, but I'm
>> interested in the performance of r.cost with the disk IO algorithm and
>> thus compare it to r.terracost with its disk IO algorithm (requires
>> numtiles > 1).
>>> If you want any real numbers on how r.cost behaves with low memory you
>>> need to reboot the machine with 1GB or better 512MB of RAM. There is
>>> no way around it. Just try it, it is easy to do. I run experiments
>>> like this all the time.
>> OK, would you mind running experiments with r.cost in grass7 and
>> r.terracost numtiles>1 so you can see for yourself?
>> I rebooted with 2500MB of RAM in order to run the same test command as
>> before on the 312 million cells region, giving about 2000MB of RAM to
>> r.cost, same like before. I used the same region and start points as
>> before because I think these settings are challenging for r.cost. My
>> test system went into swap space, all memory was used up (system file
>> cache was in swap anyway, OS needs some RAM too), and r.cost took, as
>> expected, longer, namely 4 hours 10 min.
>> Still much less than the 24 hours 22 min of r.terracost with memory=2000
>> and 8GB of system RAM...
>> The latest version of r.cost (r39749) needs 2 hours 30 min with 2500MB
>> of RAM and 2000MB of RAM assigned to it, remainder used by OS.
>> >From a user's perspective, one reason or side-effect concerning modules
>> with disk IO algorithms is IMO that you do not need to use up all
>> available system memory and can still do other things in parallel, so I
>> would always assign max 75% percent of RAM to these modules and can
>> still do other work, potentially preventing the system from caching
>> files.
>> BTW, there was a typo in my g.region command, must be res=30 in order to
>> get 312 million cells, sorry!
>> Markus M
>>> -Laura
>>> On Nov 14, 2009, at 6:51 AM, Markus Metz wrote:
>>>> Hi Laura,
>>>> Laura Toma wrote:
>>>>> my experience is that , if you want to see how an application would
>>>>> behave with 500 MB of RAM, you have to physically reboot the machine
>>>>> with 500 MB of RAM (it's very easy to do this on a Mac, and
>>>>> relatively
>>>>> easy on Linux. on windows, i don't know).
>>>>> if the machine has more than 500MB RAM, even if you restrict the
>>>>> application to use less, the system gives it all it can. in your
>>>>> setup, it is almost as if r.cost would run fully in memory, because
>>>>> even it it places the segments on disk, the system file cache fits
>>>>> all
>>>>> segments in memory. the same is true for terracost, its streams
>>>>> fit in
>>>>> memory. but using tiles has a big CPU overhead, which is why it is
>>>>> slower.
>>>> I haven't rebooted my Linux box with less RAM, but I set up a test
>>>> region with about 312 million cells (details below), I think we can
>>>> agree that this is for current standards a pretty large region, maybe
>>>> not in the future. Your argument still holds true that r.cost may have
>>>> some advantage because its temp files are much smaller than the temp
>>>> files of r.terracost and therefore a larger proportion can be
>>>> cached by
>>>> the system (beyond the control of the module). I could however see
>>>> a lot
>>>> of disk IO on both modules.
>>>> For 312 million cells, r.cost needed 51 min, r.terracost needed 24
>>>> h 22
>>>> min, both got 2GB memory.
>>>> Now that sounds like really bad news for r.terracost. But this is not
>>>> the whole truth. First, I had to tweak r.cost a little bit in order to
>>>> be so fast, still have to come up with a solution to do that
>>>> tweaking in
>>>> the module. Second, r.cost may suffer more from memory reduction, not
>>>> physical RAM reduction, than r.terracost. Reducing the percent_memory
>>>> option already slows the module down considerably. But that is also
>>>> true
>>>> for r.terracost, there the bottleneck seems to be INTERTILE DIJKSTRA
>>>> which took well over 12 hours with heavy disk IO and full memory
>>>> consumption. Third, r.cost performs better with less start points
>>>> keeping region settings constant. I'm not sure if this applies as well
>>>> to r.terracost.
>>>> In summary, I think that on even larger regions, say >1 billion cells,
>>>> and many small separate start points (>100 000), r.terracost should
>>>> outperform r.cost, but I would not bet on it ;-) For what I guess is
>>>> current everyday use (< 100 million cells), r.cost in grass7 might
>>>> most
>>>> of the time outperform r.terracost with numtiles>1, sometimes
>>>> considerably as in my tests. Speed performance of r.cost is
>>>> variable and
>>>> dependent on the combination of region size, number and
>>>> distribution of
>>>> start points, and the amount of memory it is allowed to use. There may
>>>> still be some scope for improvement in r.cost, I just did a quick job
>>>> there, no in-depth code analysis (yet). The extraordinarily large temp
>>>> files of r.terracost (total 64GB, largest single file was about
>>>> 56GB, no
>>>> typo) could be a handicap when processing such large regions. Finally,
>>>> the results of the tests I did are valid for my test system only, they
>>>> will be different on other systems.
>>>>> when i did some preliminary testing, i rebooted the machine with
>>>>> 512MB
>>>>> RAM, and ran r.cost on grids of 50M-100M cells. it was slow,
>>>>> completely IO bound, and took several hours or more. or if you use
>>>>> 1GB
>>>>> of RAM, you may need to go to larger grids.
>>>> Please test r.cost in grass7 yourself, and maybe share your test
>>>> commands, then others can run the tests too and compare.
>>>> Here is my test region:
>>>> The 312 million cells test region was created in the North Carolina
>>>> sample dataset with
>>>> g.region rast=elev_state_500m at PERMANENT res=40
>>>> Then I created a cost layer with
>>>> r.mapcalc "cost = 1"
>>>> You wanted many start points, so I generated 10000 start points with
>>>> v.random output=start_points_10000 n=10000
>>>> and converted this vector to raster with
>>>> v.to.rast start_points_10000 use=val val=1 out=start_points_10000 --o
>>>> The test command for r.cost was
>>>> time r.cost input=cost start_rast=start_points_10000
>>>> output=dist_random_10000 percent_memory=40 --o
>>>> This setting was equivalent to 2 GB of memory.
>>>> time:
>>>> real 51m18.172s
>>>> user 34m4.067s
>>>> sys 0m45.100s
>>>> For r.terracost, I used as temp dir again a directory on a separate
>>>> hard
>>>> drive, faster than the one that r.cost used, so let's say
>>>> tmpdir="/path/to/some/fast/dir"
>>>> and the test command for r.terracost was
>>>> time r.terracost in=cost start_rast=start_points_10000
>>>> out=dist_random_10000_terracost STEAM_DIR=$tmpdir VTMPDIR=$tmpdir
>>>> memory=2000 numtiles=20788 --o
>>>> numtiles=20788 I got with r.terracost -i
>>>> time:
>>>> real 1453m37.022s
>>>> user 513m56.549s
>>>> sys 43m38.519s
>>>> Sorry for that long post!
>>>> Markus M
