[GRASS-dev] Re: [GRASS GIS] #369: r.mapcalc not correctly
determining null space around r.external data set
trac at osgeo.org
Thu Dec 3 14:51:59 EST 2009
#369: r.mapcalc not correctly determining null space around r.external data set
Reporter: dickeya | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Changes (by dickeya):
* version: svn-develbranch6 => 6.4.0 RCs
Comment:
Still seeing this problem - here is my exact workflow:
r.external in=N61E043_small_nd.tif out=N61E043_small_nd
g.region -a n=62.0087569444 s=60.9912430556 w=42.9912430556
e=44.0087569444
r.mapcalc "temp_null=if(isnull(N61E043_small_nd),1,null())"
I should be seeing a continuous ring of nodata around the raster. Instead
I get the first and last row, and none of the first and last column
(except those pixels in the first and last row).
If I run r.in.gdal, the routine works as expected.
Ticket URL: <http://trac.osgeo.org/grass/ticket/369#comment:1>
