[GRASS-dev] Re: [GRASS GIS] #831: v.category options sum, del,
and add do nothing
trac at osgeo.org
Sun Dec 6 13:07:34 EST 2009
#831: v.category options sum, del, and add do nothing
Reporter: isaacullah | Owner: martinl
Type: enhancement | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: v.category
Platform: All | Cpu: All
Comment (by cmbarton):
The point is that there is currently a module accessible to all users that
when used as directed will destroy the linkage between a file of vector
objects and the attribute data that are linked to those objects. If there
is no connection between the vector file and an attribute table, as was
the case in GRASS 5, the way v.category works is not at all a problem.
In the GRASS of today, where the default is to have attribute tables
linked with vector objects, this is a big problem. Once executed, the
linkage destruction is irrecoverable. Imagine a file with 10,000 points
and 10,000 linked records. At the best, running v.category would result in
hair-tearing crisis. At the worst, the wrong vector objects would become
imperceptibly linked with the wrong attribute records producing serious
data corruption.
I'm not sure how db.execute will help reconnect this either. Once the cats
in the vector objects are changed, there is no way to reconnect them
except to inspect them one at a time and redo the data table. In any
setting with attribute data linked to vector objects, running v.category
seems very dangerous.
Ticket URL: <http://trac.osgeo.org/grass/ticket/831#comment:11>
