[GRASS-dev] GUI console example 2
Michael Barton
michael.barton at asu.edu
Mon Dec 7 01:25:10 EST 2009
Here is a more developed version of the GUI console.
Integrating this diff in GRASS 6.5 (develbranch_6) will activate the
current output window and make it an input console too. This also has
command history and autocompletion for maps/data file entry.
History: press ctrl-up or ctrl-down arrows to move through the command
history
Autocompletion: press ctrl-space when the cursor is positioned after
an "=" (r.info map=^ for example). You'll get a list of maps/data
elements. Use the arrow keys, mouse, or type the first few letters of
a map name to scroll to the item you want. Press enter or click with a
mouse to insert it.
Running commands: Place the cursor anywhere on a line with a command
and press enter. The command will run. Non-interactive display
commands (e.g., d.rast, d.grid, d.vect) will render in the display
canvas and will be added to the layer tree for later manipulation. You
can even position the cursor on commands echoed from using the menus,
edit the command, press enter, and run the command again.
It does not yet incorporate Martin's GRASS command autocompletion, but
these could be done as tooltips.
Michael
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20091206/a3f46ba1/console_example2.obj
