[GRASS-dev] Error while compiling i.pr Windows GRASS6.4
António Rocha
antonio.rocha at deimos.com.pt
Mon Dec 7 08:51:17 EST 2009
Hello Glynn and everyone
You can find as an annex to this email the output of the msys make command.
As far as I can see everrything is FINE :) and working.
Just one question: during compilation i got these errors: ERROR:
G_getenv(): Variable LOCATION_NAME not set
Is this associated with manual html page that is created with the
compilation?
Thanks Glynn, you were really helpful
Best Regards,
Antonio Rocha
Glynn Clements wrote:
> drand48() is a standard function on most Unix systems, but Windows
> doesn't have it. If you look in include/config.h, you'll see:
> /* define if drand48() exists */
> /* #undef HAVE_DRAND48 */
> It's easy enough to simulate it; the following is adapted from
> raster/r.mapcalc/xrand.c:
> #if !defined(HAVE_DRAND48)
> #define drand48() ((double)rand()/((double)RAND_MAX + 1))
> #endif
> The above should either be added to the top of i.pr/PRLIB/svm.c (if
> that is the only file which needs it), or added to
> i.pr/include/global.h (if several files need it).
> OTOH, if the algorithm requires a high level of randomness, it might
> need something better; Windows' rand() function only returns 15 bits
> of data, which may not be enough.
> A more accurate solution is:
> #if !defined (HAVE_DRAND48)
> #if defined(HAVE_LONG_LONG_INT)
> static unsigned long long state;
> /* see:
> * http://www.opengroup.org/onlinepubs/9699919799/functions/drand48.html
> static unsigned long long next(void) {
> state = (0x5DEECE66DULL * state + 0xB) & 0xFFFFFFFFFFFFULL;
> return state;
> double drand48(void) {
> return (double) next() / 0x1000000000000ULL;
> #else
> /* no drand48(), no "long long" type, don't know whether "long"
> * is 64-bit and can't be bothered implementing multi-word
> * arithmetic, so we'll have to live with this crude approximation
> #endif
> #endif
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4666 (20091207) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
make: Entering directory `/c/grass6/tests/i.pr'
c:/grass6/include/Make/Grass.make:418: warning: overriding commands for target `/c/grass6/bin'
c:/grass6/include/Make/Grass.make:409: warning: ignoring old commands for target `/c/grass6/bin'
PRLIB
make[1]: Entering directory `/c/grass6/tests/i.pr/PRLIB'
gcc -I/c/grass6/include -I/c/OSGeo4W/apps/gdal-16/include -I/c/OSGeo4W/include -g -O2 -I/c/OSGeo4W/apps/gdal-16/include -I/c/OSGeo4W/include -I/c/grass6/include -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/c/grass6/include -o OBJ./a/bootstrap.o -c bootstrap.c
gcc -shared -o /c/grass6/lib/libgrass_pr.6.4.0svn.dll -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib OBJ./a/blob.o OBJ./a/bootstrap.o OBJ./a/dist.o OBJ./a/eigen.o OBJ./a/entropy.o OBJ./a/features.o OBJ./a/features_selection.o OBJ./a/getline.o OBJ./a/gm.o OBJ./a/integration.o OBJ./a/lu.o OBJ./a/matrix.o OBJ./a/min_quadratic.o OBJ./a/nn.o OBJ./a/open.o OBJ./a/pca.o OBJ./a/percent.o OBJ./a/random.o OBJ./a/read_models.o OBJ./a/soft_margin_boosting.o OBJ./a/sort.o OBJ./a/stats.o OBJ./a/svm.o OBJ./a/test.o OBJ./a/training.o OBJ./a/tree.o OBJ./a/write_matrix.o -lgrass_gmath -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz c:/grass6/lib/gis/OBJ./a/dllmain.o && \
(cd /c/grass6/lib; ln -f -s libgrass_pr.6.4.0svn.dll /c/grass6/lib/libgrass_pr.dll)
make[1]: Leaving directory `/c/grass6/tests/i.pr/PRLIB'
i.pr_blob
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_blob'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.model.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_blob'
make /c/grass6/docs/html/i.pr.model.html HTMLSRC=/c/grass6/bin/i.pr.model.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_blob'
if [ "/c/grass6/bin/i.pr.model.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.model.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.model.tmp.html ; true ; fi
ERROR: G_getenv(): Variable LOCATION_NAME not set
c:/grass6/tools/mkhtml.sh i.pr.model ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.model.tmp.html /c/grass6/docs/html/i.pr.model.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_blob'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_blob'
make mancmd
make[2]: Nothing to be done for `mancmd'.
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_blob'
i.pr_classify
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_classify'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.classify.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_classify'
make /c/grass6/docs/html/i.pr.classify.html HTMLSRC=/c/grass6/bin/i.pr.classify.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_classify'
if [ "/c/grass6/bin/i.pr.classify.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.classify.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.classify.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.classify ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.classify.tmp.html /c/grass6/docs/html/i.pr.classify.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_classify'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_classify'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_classify'
i.pr_features
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_features'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.features_additional.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_features'
make /c/grass6/docs/html/i.pr.features_additional.html HTMLSRC=/c/grass6/bin/i.pr.features_additional.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_features'
if [ "/c/grass6/bin/i.pr.features_additional.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.features_additional.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.features_additional.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.features_additional ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.features_additional.tmp.html /c/grass6/docs/html/i.pr.features_additional.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features'
i.pr_features_additional
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_additional'
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_additional'
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_additional'
make[3]: `/c/grass6/docs/html/i.pr.features_additional.html' is up to date.
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_additional'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_additional'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_additional'
i.pr_features_extract
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_extract'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.features_extract.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_extract'
make /c/grass6/docs/html/i.pr.features_extract.html HTMLSRC=/c/grass6/bin/i.pr.features_extract.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_extract'
if [ "/c/grass6/bin/i.pr.features_extract.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.features_extract.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.features_extract.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.features_extract ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.features_extract.tmp.html /c/grass6/docs/html/i.pr.features_extract.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_extract'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_extract'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_extract'
i.pr_features_selection
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_selection'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.features_selection.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_selection'
make /c/grass6/docs/html/i.pr.features_selection.html HTMLSRC=/c/grass6/bin/i.pr.features_selection.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_features_selection'
if [ "/c/grass6/bin/i.pr.features_selection.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.features_selection.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.features_selection.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.features_selection ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.features_selection.tmp.html /c/grass6/docs/html/i.pr.features_selection.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_selection'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_selection'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_features_selection'
i.pr_model
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_model'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.sites_aggregate.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_model'
make /c/grass6/docs/html/i.pr.sites_aggregate.html HTMLSRC=/c/grass6/bin/i.pr.sites_aggregate.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_model'
if [ "/c/grass6/bin/i.pr.sites_aggregate.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.sites_aggregate.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.sites_aggregate.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.sites_aggregate ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.sites_aggregate.tmp.html /c/grass6/docs/html/i.pr.sites_aggregate.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_model'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_model'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_model'
i.pr_statistics
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_statistics'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.statistics.exe OBJ./a/cell.o OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_statistics'
make /c/grass6/docs/html/i.pr.statistics.html HTMLSRC=/c/grass6/bin/i.pr.statistics.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_statistics'
if [ "/c/grass6/bin/i.pr.statistics.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.statistics.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.statistics.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.statistics ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.statistics.tmp.html /c/grass6/docs/html/i.pr.statistics.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_statistics'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_statistics'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_statistics'
i.pr_subsets
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_subsets'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.subsets.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_subsets'
make /c/grass6/docs/html/i.pr.subsets.html HTMLSRC=/c/grass6/bin/i.pr.subsets.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_subsets'
if [ "/c/grass6/bin/i.pr.subsets.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.subsets.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.subsets.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.subsets ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.subsets.tmp.html /c/grass6/docs/html/i.pr.subsets.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_subsets'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_subsets'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_subsets'
i.pr_training
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_training'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.training.exe OBJ./a/conv.o OBJ./a/graphics.o OBJ./a/main.o OBJ./a/mouse.o OBJ./a/points.o OBJ./a/sites.o OBJ./a/title.o OBJ./a/view.o OBJ./a/write_map.o OBJ./a/zoom.o OBJ./a/zoom2.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_training'
make /c/grass6/docs/html/i.pr.training.html HTMLSRC=/c/grass6/bin/i.pr.training.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_training'
if [ "/c/grass6/bin/i.pr.training.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.training.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.training.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.training ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.training.tmp.html /c/grass6/docs/html/i.pr.training.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_training'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_training'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_training'
i.pr_uxb
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_uxb'
gcc -L/c/grass6/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/apps/gdal-16/lib -L/c/OSGeo4W/lib -o /c/grass6/bin/i.pr.uxb.exe OBJ./a/main.o C:/grass6/fmode.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_display -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lpng -lz -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lfreetype -liconv -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_uxb'
make /c/grass6/docs/html/i.pr.uxb.html HTMLSRC=/c/grass6/bin/i.pr.uxb.exe
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_uxb'
if [ "/c/grass6/bin/i.pr.uxb.exe" != "" ] ; then GISRC=/c/grass6/demolocation/.grassrc64 GISBASE=c:/grass6 PATH="/c/grass6/bin:$PATH" PATH="/c/grass6/bin:/c/grass6/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/svnserver:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/usr/bin" LC_ALL=C /c/grass6/bin/i.pr.uxb.exe --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.uxb.tmp.html ; true ; fi
c:/grass6/tools/mkhtml.sh i.pr.uxb ; mkdir -p /c/grass6/docs/html ; /bin/install -c -m 644 i.pr.uxb.tmp.html /c/grass6/docs/html/i.pr.uxb.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /bin/install -c -m 644 $file /c/grass6/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_uxb'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_uxb'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_uxb'
i.pr_sites_aggregate
make[1]: Entering directory `/c/grass6/tests/i.pr/i.pr_sites_aggregate'
make htmlcmd
make[2]: Entering directory `/c/grass6/tests/i.pr/i.pr_sites_aggregate'
make[3]: Entering directory `/c/grass6/tests/i.pr/i.pr_sites_aggregate'
make[3]: `/c/grass6/docs/html/i.pr.sites_aggregate.html' is up to date.
make[3]: Leaving directory `/c/grass6/tests/i.pr/i.pr_sites_aggregate'
make[2]: Leaving directory `/c/grass6/tests/i.pr/i.pr_sites_aggregate'
make mancmd
make[1]: Leaving directory `/c/grass6/tests/i.pr/i.pr_sites_aggregate'
make: Leaving directory `/c/grass6/tests/i.pr'
http://www.eset.com
