[GRASS-dev] Re: missing grass configuration files
Michael Barton Michael.Barton at asu.edu
Tue Dec 8 21:25:30 EST 2009
Thanks a million. This project is so great.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 8, 2009, at 6:15 PM, William Kyngesburye wrote:
> On Dec 8, 2009, at 1:58 PM, Glynn Clements wrote:
>> Michael Barton wrote:
>>> I found the file. It is now called "rc" but it is not ending up in
>>> ~/.grass7. Instead, it is just going into HOME.
>>> So this is a bug somewhere, but I'm not sure where. In Init.sh?
>> lib/init/*.
>> lib/init/Makefile replaces @GRASS_CONFIG_DIR@ with $
>> (GRASS_CONFIG_DIR)
>> in init.sh, grass.py and init.bat. However:
>> 1. init.sh uses $GRASS_CONFIG_DIR, but doesn't define it; it needs a
>> line like:
>> 	GRASS_CONFIG_DIR=@GRASS_CONFIG_DIR@
>> GISRC is defined as:
>> 	GISRCRC="$HOME/$GRASS_CONFIG_DIR/rc"
>> so the missing definition for GRASS_CONFIG_DIR causes it to be set to
>> "$HOME//rc".
> Or better
> if [ ! "$GRASS_CONFIG_DIR" ] ; then
> 	export $GRASS_CONFIG_DIR
> fi
> so it can be overridden by the grass startup to define a build-
> specific location.
> ...which I just added in r39949.
> Michael - I also updated the scripts that were using the old user
> addon paths, and made the startup override GRASS_CONFIG_DIR so that
> it's in the user's Preferences folder on OSX instead of the hidden
> folder (also more secure).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is
> over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people
> of the allied nations devoted an entire year exclusively to hating
> the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
