[GRASS-dev] Re: [GRASS GIS] #829: v.in.ogr: when pointing to a
folder import of vectors can produce wrong results
trac at osgeo.org
Fri Dec 11 02:31:38 EST 2009
#829: v.in.ogr: when pointing to a folder import of vectors can produce wrong
results
Reporter: lutra | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Resolution: invalid | Keywords: v.in.ogr
Platform: All | Cpu: x86-32
Comment (by pcav):
I think most users would expect a different behaviour from this command,
importing all the shp in a folder as different GRASS vectors. It would be
good to make this unexpected behaviour clear from the description of the
command (also in the QGIS plugin)
Ticket URL: <http://trac.osgeo.org/grass/ticket/829#comment:2>
