[GRASS-dev] Re: [GRASS GIS] #829: v.in.ogr: when pointing to a folder import of vectors can produce wrong results
GRASS GIS trac at osgeo.org
Mon Dec 14 10:08:20 EST 2009
results
  Reporter:  lutra    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  closed
  Priority:  major    |   Milestone:  6.4.0
 Component:  Vector   |     Version:  6.4.0 RCs
Resolution:  invalid  |    Keywords:  v.in.ogr
  Platform:  All      |         Cpu:  x86-32
Comment (by mmetz):
 Replying to [comment:4 lutra]:
 > > Importing all shapefiles in a folder as different grass vectors can be
 done in the wxGUI with
 > > File -> Import vector map -> Multiple vector data import using OGR
 > is this made trough a python script?
 It's written in python, but not as a single script, it is embedded into
 the wxGUI and only available when using the wxGUI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/829#comment:5>
