[GRASS-dev] Re: [GRASS GIS] #785: wx location wizard: doesn't show all datum transform opts
GRASS GIS trac at osgeo.org
Tue Dec 15 06:06:11 EST 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  reopened
  Priority:  normal  |   Milestone:  6.4.0
 Component:  wxGUI   |     Version:  svn-develbranch6
Resolution:          |    Keywords:  location wizard
  Platform:  All     |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:38 cmbarton]:
 > This is kind of weird. I just checked in the code I updated
 > and recompiled tonight. The spin control works fine on my Mac.
 > It starts at 30 (midway between 1 and 60) and easily spins both
 > ways.
 > Can you update and check this? See if the spin control is still
 > stuck? I think I'm using very basic and generic controls here.
 yup, still stuck. I just updated the min utm zone so now it is stuck at 1
 not zero.
 I added a debug message, val.isdigit() is failing L730 hence the reset and
 it not allowing me to go on. I tried to print 'val' to the terminal but it
 came back empty (?)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/785#comment:39>
