[GRASS-dev] Re: [GRASS GIS] #693: wxGUI menus: i.ortho.photo locks
up GUI
trac at osgeo.org
Tue Dec 15 08:13:45 EST 2009
#693: wxGUI menus: i.ortho.photo locks up GUI
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: i.ortho.photo
Platform: All | Cpu: x86-64
Comment (by hamish):
it still locked. the problem was that it was waiting for d.mon to return
before launching into grass-run.src
I've now combined Glynn's fix/explanation with Michael's Mac fix in r40019
for devbr6. I haven't backported to 6.4 yet pending testing.
highlights: instead of gcmd.RunCommand() use gcmd.Command([list],
wait=False). wait=False was needed allow the GUI to continue.
I'm not sure of the RENDER_IMMEDIATE directly after. I assume it just has
to be set for the launch of the command, and as soon as it is forked it
can be set back.
no idea if the WinNT version works or is even meaningful, as d.mon will
have failed there ? Or does Cygwin will call its os.environ as Windows_NT
so for that it is needed? I guess we could catch the d.mon call but really
r.digit, i.ortho.photo, etc should be greyed out on native WinGrass before
then.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/693#comment:14>
