[GRASS-dev] change in vector area format?
Michael Barton c.michael.barton at gmail.com
Tue Dec 15 09:49:15 EST 2009
Thanks for the explanation. I won't worry about running v.build in
GRASS 7 then. Somewhere along the line, we could probably use a script
that automatically runs v.build on all vectors in a mapset to build
the file based spatial index.
BTW, I'm glad to see interest in my v.what suggestions. These were an
important component of a set of suggestions to standardize and enhance
vector processing.
Best
Michael
On Dec 15, 2009, at 6:06 AM, Markus Metz wrote:
> Michael Barton wrote:
>> Maybe I just missed the announcement. But I was surprised to find
>> that
>> areas no longer displayed as areas in GRASS 7, but only as
>> boundaries.
>> After trying multiple vector area files and considerable futzing with
>> various settings I got an error that said that the topology was bad.
>> When I rebuilt topology I could again display areas.
>> Does this rebuilding of vector areas under GRASS 7 have any negative
>> repercussions for displaying the same files in GRASS 6?
> Up to now, grass7 vectors are fully compatible with grass6 vectors:
> grass6 can work with grass7 vectors. Not the other way around, because
> in grass7, the spatial index is again file-based, not built on the
> fly.
> Consequently, grass7 can open a grass6 vector only on level 1 (no
> topo)
> and areas are not available until topo has been rebuilt.
> This change was submitted to trunk on July 13 2009 as r38385, see also
> [1]. The announcement is here [2].
> We could change grass7 behaviour to built sidx on the fly if it is not
> available, but that defeats the purpose of the file-based spatial
> index.
> Just run v.what on a larger vector map once in grass6 and once in
> grass7
> after rebuilding topo, elev_lid792_bepts in nc_spm_08 is a good
> example.
> Your suggestions about additional functionality in v.what would also
> heavily profit from it (is on my todo list...).
> Markus M
> [1] https://trac.osgeo.org/grass/wiki/Grass7/VectorLib
> [2] http://lists.osgeo.org/pipermail/grass-dev/2009-July/045098.html
