[GRASS-dev] Re: [GRASS GIS] #836: quiet processing in v.net.path
GRASS GIS trac at osgeo.org
Tue Dec 15 21:16:30 EST 2009
  Reporter:  09091968      |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement   |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Vector        |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  v.net.path
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by hamish):
 It uses G_warning(), which can not be surpressed at run-time.
 if you run GRASS with a MSys terminal you could redirect the error
 messages to a file or to the dustbin with something like:
  v.net.path ... options ... 2> v.net.path.err
 or from the dos prompt with something like
  v.net.path ... > nul:
 In general throwing away all warning and error messages can be quite
 counter productive as you might miss the real ones.
 I don't think there will be a way to shut them off from the GUI right now.
 Q: are those messages (from v.net.path/path.c) informational (and so
 should use G_message()) or actually quite important to know (so stay with
 G_warning()) ?
 I don't know enough about the module to answer that.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/836#comment:1>
