[GRASS-dev] Re: [GRASS GIS] #835: v.out.ogr -c flag doesn't work?
GRASS GIS trac at osgeo.org
Wed Dec 16 05:09:01 EST 2009
  Reporter:  lutra    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  closed
  Priority:  normal   |   Milestone:  6.4.0
 Component:  Vector   |     Version:  6.4.0 RCs
Resolution:  invalid  |    Keywords:
  Platform:  Linux    |         Cpu:  x86-32
Changes (by lutra):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 You are right. I tested the spearfish dataset and it works fine. Probably
 the vector I used before is not as I supposed. I'll make further tests but
 I guess that meanwhile I can close this as invalid.
Ticket URL: <http://trac.osgeo.org/grass/ticket/835#comment:2>
