[GRASS-dev] Re: [GRASS GIS] #839: wxGUI: About GRASS menu item
broken
trac at osgeo.org
Thu Dec 17 07:23:01 EST 2009
#839: wxGUI: About GRASS menu item broken
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by hamish):
Replying to [comment:4 marisn]:
> Could this be locale-dependent issue? Michael is using en_US
> locale and thus all unicode/anycode text == ascii, which may not
> be true for other locales. Just guessing without reading code.
perhaps, but I don't think so. I'm pretty sure the workstation I was
testing on before is set up as LANG=C, and on a second machine here I'm a
little surprised to see it is actually set to en_NZ instead of C or en_US.
(usually it's just less trouble that way, and dealing with the spelling
differences isn't a big deal, I just resolve myself to spelling poorly in
both contexts ;)
On this second machine it works -- same debian version, only difference
AFAIK is 32bit P4 instead of 64bit AMD. shrug. does it fail for anyone
else? ubuntu users?
I also found that the 2 .csv files were missing, but the translators and
contributers tabs are missing unless I drag the window wider. also the
translators tab is open upon launch, but the info one should be. also I
find scrolling with the mouse wheel down the gpl and authors list that the
text is ''highly'' jumpy. is "contributers" redundant; shouldn't we just
take care to merge that into Authors? (?)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/839#comment:6>
