[GRASS-dev] more help with v.category...
Markus Metz markus.metz.giswork at googlemail.com
Fri Dec 18 05:16:35 EST 2009
Isaac Ullah wrote:
> So, how can I make all 159 individual areas have unique category
> numbers?!?!?
I think you have to delete all categories first, because v.category will
only add a category to a vector object if none is set (that information
is missing in the manual AFAICT). Or you add categories to a new layer.
Markus M
