[GRASS-dev] Re: [GRASS GIS] #587: svn versions should better reflect svn rev
GRASS GIS trac at osgeo.org
Sat Dec 19 13:11:00 EST 2009
  Reporter:  hamish       |       Owner:  martinl
      Type:  enhancement  |      Status:  reopened
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  g.version
  Platform:  All          |         Cpu:  All
Comment (by martinl):
 Replying to [comment:28 glynn]:
 > Replying to [comment:27 hamish]:
 > > 'svnversion' gives the wrong answer. e.g. for 6.2svn the result should
 > > be 6.2.svn30152 but after 'cd releasebranch_6_2; svn up' svnversion
 > > reports r40065. ie the global repo rev number, not the latest change
 > > to the branch rev.; is the relevant one.
 > You can use `svnversion -c` to get the last-changed revision, which is
 (presumably) what we want here.
 Right, should be fixed in r40066.
Ticket URL: <http://trac.osgeo.org/grass/ticket/587#comment:29>
