[GRASS-dev] Re: IMPORTANT: [GRASS GIS] #837: Memory leaks in
r.example
Hamish
hamish_b at yahoo.com
Mon Dec 21 02:02:45 EST 2009
Glynn wrote:
> Essentially, you don't know whether it's safe to free the mapset
> string returned from G_find_*. If it isn't and you free it, it can
> cause a crash. If it is and you don't free it, you've leaked some
> memory.
> Most of the time this isn't a problem, but the null bitmap code calls
> these functions every NULL_ROWS_INMEM (== 8) rows. For large maps (or
> for large numbers of maps, e.g. r.series), this could add up (even if
> mapset names are short, there's an overhead for each malloc()'d
> block).
for some perspective, what's the maximum damage? what's the typical damage?
as a "worst plausible case" say you have 50,000 x 50,000 cell raster
output from r.sun, and you have 365 of them you want to run them through
r.series.
as a "typical heavy load case" let's say a 4000x4000 cell raster with
a dozen of them to run through r.series.
if the leak is a *mapset string, from your above comments above and the
G_find_file() code that means GMAPSET_MAX (256) bytes+whatever system
overheads that incurs.
for these two cases that would be:
expected worst case:
50000/8 * 256 * 365 = 570mb
normal heavy load:
4000/8 * 256 * 12 = 1.5mb
how's my math?
compare the leak to r.series memory req for that sized map:
does it keep 8 rows of all maps in memory during processing(??)
(not sure, but going with that...)
8 rows * 50k columns * sizeof(DCELL) * 365 maps = 570mb
so total mem use at completion = 1.2gb
if all of the above is correct (& I'm not sure it is), then I would say
that anyone running the above worse case is probably running it on a
system which has >2gb ram, & so not a cause for panic.
Hamish
