[GRASS-dev] [GRASS GIS] #843: v.digit broken on new WinGrass release
GRASS GIS trac at osgeo.org
Mon Dec 21 12:11:20 EST 2009
 Reporter:  cnielsen          |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.0
Component:  Vector            |     Version:  unspecified
 Keywords:  wingrass,v.digit  |    Platform:  MSWindows XP
      Cpu:  x86-64            |
 Vector digitizing windows open properly, both in the tcltk and the new
 wxpython menu item.
 However after a feature is digitized, as I right-click to finish the
 feature, the window closes and the following error message shows up in the
 "Output" window or "Command output" tab depending on the GUI
 v.digit map=test2 at user1
 ERROR: F_open is not supported on Windows
 Building topology for vector map <test2>...
 Registering primitives...
 2 primitives registered
 18 vertices registered
 Building areas...
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
Ticket URL: <http://trac.osgeo.org/grass/ticket/843>
