[GRASS-dev] Re: [GRASS GIS] #580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
GRASS GIS trac at osgeo.org
Mon Dec 21 17:27:35 EST 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  blocker       |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by hamish):
 > Replying to [comment:14 hamish]:
 > > does not work:
 > >  - wxGUI Config->Working Environ->Change Default GUI
 > >    (Traceback error in command output tab ... Unable to fetch
 interface description for command 'g.change.gui.py'.)
 Replying to [comment:17 hellik]:
 > there seems to be no g.change.gui(.py)
 sure there is. look at the title of this bug report.
 The source is in gui/scripts/, it gets installed to
 $GISBASE/etc/gui/scripts/. All the wrapper scripts in there fail on
 wingrass. These wrapper scripts are needed to make command line based
 modules more GUI dialog friendly, or to extract particular targted
 functionality.
 https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/gui/scripts/
 the above quoted menu path shows where it is in the wx menu.
 > g.gui is working on windows
 that is something different (a normal C module, not a python wrapper
 script).
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:18>
