[GRASS-dev] Re: [GRASS GIS] #580: WinGRASS:
$GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Mon Dec 21 21:32:15 EST 2009
#580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by cmbarton):
Replying to [comment:21 glynn]:
> Replying to [comment:18 hamish]:
> > All the wrapper scripts in there fail on wingrass.
> My first guess would be that something isn't setting shell=True in the
Popen constructor.
> On Windows, shell=False (the default) only works for .exe files. If you
want to be able to "run" .py, .bat etc files, you have to set shell=True.
> [[BR]]
[[BR]]
On Mac we only need to supply the wxPython binaries to ensure that the
correct version is run I think. But maybe william will know better.[[BR]]
[[BR]]
> [shell=True uses `cmd /c ...`, while shell=False calls !CreateProcess()
directly.]
> lib/python/core.py has its own versions of Popen() and call() which
default to shell=True on Windows (Unix should always use shell=False). The
wx GUI should be doing something similar.
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:22>
